Chase Card Activation Not Working – How to Fix It
If your new Chase card is not activating, there are several simple troubleshooting steps you can try. Chase provides activation options online, through the Chase Mobile app, and by phone, depending on the type of card. If you're using Chase.com/Activate, make sure you're following the instructions provided with your card.
Why Is My Chase Card Activation Not Working?
Common reasons include:
  • Incorrect card information was entered.
  • Your card or account information could not be verified.
  • The activation page or app is experiencing a temporary technical issue.
  • Your card is a replacement or newly issued card and requires additional verification.
  • The phone number associated with your Chase account may need to be updated.
How to Fix Chase Card Activation Problems
1. Check Your Card Information
Make sure you are entering the information exactly as shown on your new Chase card. If you're activating by phone, follow the instructions provided with the card.
Chase recommends checking the activation instructions included with your card.
2. Try Activating Online Again
If Chase.com/Activate isn't working, close the browser and try again. You can also try a different browser or device and make sure your internet connection is stable.
For security, only use the official Chase website or the activation instructions provided with your card.
3. Try the Chase Mobile App
If you have access to your Chase account, sign in through the official Chase Mobile app and check the available card-management options. Chase also provides account-management features through its app.
4. Activate by Phone
If online activation continues to fail, use the phone number provided on your card or activation sticker. Chase notes that cards can generally be activated by following the issuer's phone instructions.
For Chase credit-card customer service, Chase currently lists 1-800-432-3117.
5. Check Whether Your Card Is Already Active
If you aren't sure whether activation went through, you can contact Chase using the number on the back of your card. Customer service can help determine whether your card is active.
6. Check Your Phone Number
If Chase is unable to verify you during activation, make sure the phone number associated with your account is current. Updating your contact information may help resolve verification problems.
Chase Debit Card Activation
If you're trying to activate a Chase debit card, Chase says you can activate it online, by calling 1-800-290-3935, or by completing a transaction at a Chase ATM using your PIN.
What If the Card Still Won't Activate?
If you've tried the available activation methods and your card still doesn't activate, return to Chase.com/Activate and carefully review the information you're entering. If the problem continues, contact Chase directly using the customer-service number printed on the back of your card.
Don't provide your card number, PIN, password, or other sensitive information to an unofficial website or person.
Frequently Asked Questions
Why can't I activate my Chase card online?
A temporary website issue, incorrect information, or an account-verification problem may prevent activation. Try Chase.com/Activate again later or use another official activation method.
Can I activate my Chase card by phone?
Yes. Follow the activation instructions provided with your card or call the appropriate Chase number.
How do I know if my Chase card is already activated?
You can contact Chase using the phone number on the back of the card. A declined transaction does not necessarily mean the card isn't activated because there can be other reasons for a decline.
What should I do if my new Chase debit card won't activate?
Try activation online, by calling 1-800-290-3935, or through a Chase ATM using your PIN.
If your Chase Card activation isn't working, first verify the card information and try Chase.com/Activate again. If the problem continues, use the Chase Mobile app or activate by phone. For unresolved activation issues, contacting Chase through the number on the back of your card is the safest option.
    • Discover Card Activation Not Working – How to Fix It
      Get quick help to resolve your Discover Card activation problem. Having trouble activating your new Discover Card? If Discover.com/Activate isn't loading, your card details aren't being accepted, or the activation process stops before completion, a ...
    • Bank of America Card Activation Not Working: How to Fix It
      Fix card activation issues and complete your Bank of America card setup securely. Having trouble activating your Bank of America card? If your Bank of America card activation is not working, a few quick checks can help identify the issue and get your ...
    • AmericanExpress.com/Activate – Card Activation Not Working
      Start the Amex Card activation process online and get your Card ready to use. If your American Express Card activation is not working, there are several simple things you can check before contacting support. The AmericanExpress.com/Activate process ...
    • How to Activate Your Chase Card Online — Chase.com/Activate
      Activate your Chase Card securely online through Chase.com/Activate. Received a new Chase Card? Activating it is an important step before you begin using it. Chase.com/Activate provides a convenient way to get started with card activation. Keep your ...
    • How to Activate a New Chase Card Online
      Activate Chase Card button for starting the online activation process for a new Chase credit card. Activating a new Chase card is an important step before using it for purchases. Depending on your card, Chase may provide activation instructions ...
